servicing trans
Old Mar 31, 2009 | 02:01 PM
fkaster01's Avatar
fkaster01
Question servicing trans
i'm going to change the fluid/filter in the trans today and I need some input on a couple rumors/myths maybe about doing this. I know for a fact that the fluid has never been changed, and i've heard that doing it now could cause problems. someone told me that the trans becomes dependent on the fluid it has in it after a while and changing it could cause the trans to burn up within a few months. is there any truth to this? Is there something I should or shouldn't do while changing the fluid and filter?
Old Mar 31, 2009 | 02:25 PM
Freightrain's Avatar
Freightrain
Well, sometimes has merit. How many miles on it?
I did mine with 74K miles and it was shuttering pretty bad. After the change, it cleared up and works great. The bottom of the pan(with the magnet) was caked with metallic. Really scrubbed it up, new filter and fluid. Presto-chango.
Re-use the rubber gasket, don't hurt it. Clean the surfaces really good, don't use a scraper that could gouge it. Brake clean and rags only. Snug it evenly, don't crank the bolts.
Old Mar 31, 2009 | 02:39 PM
quicklook2's Avatar
quicklook2
always helps to know which trans.
regardless, drain pan, drain convertor, buy ford filter, use quality fluid, get a big pan, the gasket usually comes with the filter.
i add i quart of lucas trans fluid that i put in boiling water to make it flow out of the bottle better.
not changing the fluid is an old wives' tale.
Old Mar 31, 2009 | 03:36 PM
fkaster01's Avatar
fkaster01
its an e4od trans with 226000 miles on it... the fluid is still kinda red, but I had problems with it the other day and it smells a little burnt now, I have to replace the vss, psom and something else to fix the issue but i wanted to change the fluid also... i figured it was an old wives tale but wanted to make sure. I'm not sure where to find a motorcraft filter either. most parts stores around here carry pro-king kits for this, would i need to get one from a dealer? I don't think saving the rubber gasket is going to be possible with that many miles on it either, we'll see i guess
copyman1
Apr 25, 2013 01:06 PM
62star
Jul 5, 2012 08:40 PM
slomafarms
1997 - 2003 F150
Apr 20, 2011 05:41 AM
marthur9789
20
Jan 9, 2011 04:38 PM
Headviking
Sep 17, 2009 06:56 AM
