Sponsored by: Real Truck
What is a good replacement steering stabilizer
Old Mar 31, 2009 | 11:35 AM
consol's Avatar
consol
I am slowly but surely replacing items on my 05 f250 4wd, 110K.
Who makes a good replacement steering stabilizer.
Stock height and I don't plan on lifting it (other than maybe a 2.5" leveling coil setup down the road).
Thanks.
Old Mar 31, 2009 | 11:37 AM
senix's Avatar
senix
If you do a leveling kit, then I would suggest getting a dual steering stabilizer. If you are leveling then I bet bigger tires are on the way too? I am running skyjacker and it does just fine. There are others.
Old Mar 31, 2009 | 11:43 AM
DAVE67FD's Avatar
DAVE67FD
It will depend on the money you want to spend. If you want just a stock replacement many have used Rough country, Rancho, Icon etc.. The same goes for the dual shock set-up if you plan on running larger tires in the future. I went with the Rough country dual set-up from 4wheeelingplus.com (p/n- 87491) and it came with the boots for $97 shipped. The singles are about maybe 1/2 that price or cheaper. Google "steering stabilizers" and it will give you plenty of ideas. The Icon is a nice set-up but not cheap.
Old Mar 31, 2009 | 08:11 PM
Fordfanatic4life's Avatar
Fordfanatic4life
any quality aftermarket suspension/shock brand will make a replacement that is WAY better then the dinky little OEM unit...
u have tons of options.. search the 'net for the best deal and get one...i dont know if i would say one brand is better then another when it comes to a steering stabilizer..
if ur tires are less then 35"s tall u can easily make use with a single unit...above that duals def. become needed...
