transfer case
Old Mar 30, 2009 | 09:54 PM
desert sled's Avatar
desert sled
transfer case
I am in the process of changing the fluids on my 1994 F-350. I noticed that when you look at the back of the transfer case there are two drain bolts,one high and one low. I am assuming the lower one is the drain and the high one is the fill point. Is this correct? Do you still use Mercon ATF fluid in this application. Thanks.
Old Mar 30, 2009 | 10:40 PM
farmert's Avatar
farmert
You are correct on both counts. Mercon Dextron is the recomended fuid.
Old Mar 30, 2009 | 11:06 PM
desert sled
Thanks for the quick response.
