tire lean??
Old Mar 30, 2009 | 08:41 PM
93 mix 'n match's Avatar
93 mix 'n match
tire lean??
hi! my 93 f150 has a baaaddd case of tire lean. the front tires lean in on the top and the back tires lean out on the top. leaving me with a penny on one side and bald on the other. the suspension has less then 30k on it, theres nothing in the truck and i have no idea why its doing this.
please help im down 4 new tires.
Old Mar 30, 2009 | 09:43 PM
octaneforce's Avatar
octaneforce
hows your front end? a bad front end can cause funky tire wear, but im not sure why your back tires are wearing out like that.
Old Mar 30, 2009 | 10:15 PM
Conanski's Avatar
Conanski
Springs are sacked, get new ones.
That's not possible unless the rear axle is bent.
Old Mar 31, 2009 | 02:27 AM
LCAM-01XA's Avatar
LCAM-01XA
What they said - old tired front springs will do this, also bad ball joints (but that's not the case at 30k miles on them). Rear axle is straight, or at least should be, no way the tires have any camber other than zero...
