HELP: gremlins stealing my r134
This is on my wife's '94 Ranger. This is the typical Ford accumulator system using R134 refrigerant. It has always been ice cold until a few days ago when she told me it was blowing warm air. When I put the gauges on it, there was no pressure at all. So I pulled all connections apart, cleaned them, and replaced all o-rings. I also replaced the orifice tube while I was at it. I then pulled a vacuum on it for 30-45 minutes, shut it off, and let it set. There was no drop in vacuum reading in four hours. I then filled it with refrigerant and some dye and was getting good cold air (32 degrees).
Twenty four hours later, it was blowing warm air again, and the gauges showed almost no pressure (the AC had not been run during this period of time). When I put the vacuum pump on it, it pulled a good vacuum and held it. There is no sign of the dye anywhere and all connections on this system are very visible. Only the evaporator is out-of-sight.
Questions: (1) Where in the world can the refrigerant be going? (2) What kind of leak can there be that will not open and leak under a vacuum but will leak under the pressure of the refrigerant?
If anybody can give me a hint of what to do or check for, I will appreciate it.
Thanks
about the only way to tell for sure without taking it apart is to get your hands on a good A/C sniffer, and start searching all the fittings. of you do not get any hits there, go inside the cab, and sniff in the vents with the fan set on low. i bet it will freak out.
