Sponsored by: Auxito
transmission question
Old Mar 30, 2009 | 10:41 AM
northeaster79's Avatar
northeaster79
I've got a quick transmission question,my father has a 1999 F150 4x4,4.2 auto.the transmission is shot and I have an aod trans from a 1989 5.0 mustang,I realize the tail shaft would be different but is the rest of the trans the same in any way?thanks in advance for any information you have.
Old Mar 30, 2009 | 01:20 PM
l-m tech's Avatar
l-m tech
99 trans u have is electroncily controlled,the on out of the 89 is controled by a tv cable.the parts inside are diff. the 99 has a wide ratio gear set and wider od band.
Old Mar 30, 2009 | 01:25 PM
northeaster79
I figured there was a difference of some sort,thanks tech.
Old Mar 31, 2009 | 05:04 PM
LxMan1's Avatar
LxMan1
Yep, two totally different animals.
I need the Mustang trans for a Mark VII though
Too bad you are so far away
