injector lines...
Old Mar 30, 2009 | 10:26 AM
99SevenPoint3's Avatar
99SevenPoint3
injector lines...
jus wanted to know if they sell what look like lil rubber seals inside of the injector line.....as of right now i havent removed mine lines so i dont have any leaks but i took a few off an truck i found in the salvage yard n they seemed to be dry n cracking off...so i really dont want to remove mine and then have a leak without a way of fixing the issue... Well thanxs for ur time ...
Old Mar 30, 2009 | 10:33 AM
LCAM-01XA's Avatar
LCAM-01XA
Steel injector lines have no o-rings in them, tis a flared coupling on both the injector and IP sides. O-rings can be found on the steel line that runs from the lift pump to the filter head (one o-ring, 3/8" ID), and on the steel line that runsfrom the filter head to the IP (two o-rings, 5/16" ID), those are the Parker Vibra-Lock type and you should be able to get them at any store that deals with Parker products. O-rings can also be found in the injector return lines, namely under the plastic caps, there are 2 o-rings per injector making for a total of 16 - the standard number for o-rings of the proper dimensions is #111, and you can have them in variety of materials and hardnesses, order a pack of 25 viton o-rings from McMaster-Carr for like $5 and be done with it.
