no running lights
Old 03-31-2009, 11:24 AM
squigler's Avatar
squigler
squigler is offline
no running lights
i have an 05 f150 i cant seem to get the running lights to work everything else works fine (on the truck) on the trailer plug is there a seperate fuse for that?
Old 03-31-2009, 06:23 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
See your owner's manual.
Old 03-31-2009, 06:37 PM
squigler's Avatar
squigler
squigler is offline
did that on line no maual its #10 hole they call it evrything but running lights!
Old 03-31-2009, 09:06 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
running lights on the trailer are tied to tail lights, right? yes, there is a fuse under the hood on the drivers fender well. i have had it blow a couple times. on my trailer, you need to have the truck not running when you plug in the trailer. if it is running, it normally blows the fuse.. i dont remember the exact one, but its probably yellow (20 amp), and the small C shape.
Old 03-31-2009, 09:08 PM
steve(ill)'s Avatar
steve(ill)
check #20 fuse for tail lights. i also lost #19 once. it is one brake lite.
Old 04-01-2009, 06:56 AM
projectSHO89
They call them "park lights". Same thing as running lights.
Owner's manual gives both the fuse and the relay information.
Guys, you MUST use the correct model year. There are variations every couple of years and, if yours is different, it doesn't apply.
