Sponsored by: Auxito
Looking for suggestions...
Old Mar 29, 2009 | 10:43 PM
DBKER31's Avatar
DBKER31
anybody have the diagram or instructions to getting the stock radio/ head unit off of a 2001 f-150? shes giving me a hard time and im getting tired!
thanx for any help! Much appreciated
Old Mar 29, 2009 | 11:51 PM
triton_2002's Avatar
triton_2002
don't really understand the question. Do you just want to take out the stock radio? If so, there are a set of holes on each side of the radio, you need to put a special tool in those holes to unlock it and be able to pull it out. The tool is a set of U shaped rods, you can usually find them at Walmart for a few bucks. You can also just cut a metal coat hanger and make your own, but it will take some trial and error to get it to unlock. You have to put both set of rods into the holes and push in (or out, I forget) and pull it out. You can also take off the dash panel around the radio for some extra room to work. Just grab the panel by the a/c vent frame (not the vents themselves) and firmly pull it out, just be carefull with the airbag on/off switch wiring, because it will come out with that wiring attached to the vent surround. Hope that helps. It's actually really easy, just take your time so you don't brake anything.
Old Mar 31, 2009 | 05:06 PM
LxMan1's Avatar
LxMan1
You have to pop off the trim around the radio first, that includes the center vents. Gently get under a corner of it and pull it off, then use the holes mentioned above to remove the radio.
Old Mar 31, 2009 | 07:28 PM
commandersander's Avatar
commandersander
4-8p nails
From the inside to outside....push (laterally) and simultaneously pull uot towards your body
Done
I assume you are putting in a video head or something aftermarket?
Old Mar 31, 2009 | 11:50 PM
DBKER31's Avatar
DBKER31
thanks guys for the advice im deff gonna use it!
and nah im just hookin a amp up to it and i already have aftermarket speakers. im not doing a sub just wanna power my speakers better
Old Apr 1, 2009 | 12:13 AM
triton_2002
the stock HU does not have RCA outputs for an amp, you'll need an amp with low level inputs, so you don't really need to pull the HU for that.
