4-wheel drive problem
Old Mar 29, 2009 | 05:12 PM
spedbugy's Avatar
spedbugy
I hooked up my utility trailer to my '98 Expedition the other day and when I hooked up the lights fuses started blowing. I had a bad ground on the trailer, so i fixed that, replaced the fuses in the truck for the trailer lights and all was fine till I figured out that my 4-wheel drive doesn't work now I turn the **** and nothing happens. I have checked every fuse I can find on the truck and found no more that had blown. Are their any inline fuses that I just haven't found yet? Also before I replaced the fuses for the trailer lights I would hear a clicking from under the truck somewhere. Any thoughts?
Old Mar 29, 2009 | 07:38 PM
alloro's Avatar
alloro
There are no in-line fuses. Did you check the fuses under the hood too, or just the ones under the dash?
If all else fails, try disconnecting the battery for 10 minutes to drain all power from the truck so that the electronics will reset.
Old Mar 30, 2009 | 09:15 AM
ExpySport's Avatar
ExpySport
I believe it is fuse #104 under the hood.
