HELP Need Axle ID
Mar 29, 2009 | 03:56 PM
HELP Need Axle ID
It is on a 1961 F250
I've looked around and all the f250's I saw had the 6bolt/screw hub in them, Is it even possible to find out from just looking at the hub?
Mar 30, 2009 | 05:49 AM
Look at the housing to see if you can ID it. If it is a Dana it should have a number stamped on the housing near the cover plate. It will be a 44, 60 or some other 2 digit number. Also go into Articles/specs on this website. I believe that there is an article on IDing axels
Mar 30, 2009 | 06:00 AM
As original 1959/72 F100/250 4WD: Dana 44's only. There were six different variations.
The Ford axle ID rectangular shaped tag was located under two of the bolts on the Dana front/rear axles...that holds the inspection cover on.
But today, the tag is usually missing.
Pic posted only show a WARN manual locking free running hub on an 8 lug F250 (aftermarket) wheel.
There were several variations of these optional WARN hubs available from Ford. Either factory installed on F100/250's, or sold at the parts counter.
It's impossible to tell what the axle is by this pic.
The AXLE code is stamped on the Warranty Plate, located on a truck of this vintage inside the glovebox door.
Ford listed the 4WD front axle code with the rear axle code, but only sporadically.
If the AXLE code is three digits, the third digit refers to the front axle.
The Dana 44 uses a different inspection cover gasket than a Dana 60.
Mar 30, 2009 | 02:51 PM
I understand that you cant tell the size by looking at the hubs, but i figured that maybe you guys might know why the hub has 8 screws instead of 6
Mar 30, 2009 | 03:37 PM
Quote:
Originally Posted by
61F250Highboy
What difference would that make? None.
The WARN hubs were an optional accessory.
There were 3 different types, 5 different models of WARN manual locking hubs used on 1959/72 F100 & F250 4WD's.
Ford did not offer a Dana 60 front driving axle until 1973.
So....if the front driving axle is
original to the truck, it's either a Dana 44-6F or a Dana 44-6F H/D.
The 44-6F has an axle capacity of 3,000 lbs, while the 44-6CF H/D has an axle capacity of 3500 lbs.
Have you looked for an ID tag, or numbers on the tubes or housing?
Mar 30, 2009 | 05:04 PM
61F250Highboy
they look like the warn premium hubs, not the standard hub. that would explain the 8 bolts instead of the 6 on the standard hubs.
Dgasman
Aug 14, 2016 09:00 PM
1961 f100 4x4
WTB - Parts & other
Oct 5, 2015 05:13 AM
1961FordGirl
New Member Introductions
Feb 20, 2014 08:26 PM
nugecrazy
Aug 15, 2007 06:41 AM
rob17san
Feb 11, 2006 09:22 AM
