You know what there Vin.. I accept your nomination. Lets see if we can pull some things together here. Id be into that. Ill let the other items at this time lay and concentrate on this. Thanks VIN.
As of now, I don't think I'm in a position to accept my nomination. I have not really been around that long. Someone that has some history on the board should get the position.
Yeah the way I look at it.. Is Zip may or not be gone and I would vote along with the others here for Zip. But whether he is truly gone or not right now is any body's guess. I figure that if we at least set the wheels in motion this whole thing will be over just as it began. I have further read into both guidelines sent from the moderator glruff, and in my understading if we dont have any nominees then it may go to the hands of FTE. And we wouldnt have a leader ( as far as I can understand.) I am prepared to keep the Chapter Leader of the BC Chapter a resident of BC. And therefore have chosen to accept the nomination given by Vin ford.
If I am chosen to repersent the BC Chapter I will try my very best to keep what Zip had here. I as well as the rest of you do miss the big man and do truely hope that everything in his life is ok and doing fine.
However I do understand that once Zip threw the towel in it had to begin.
Thank You
Rick ( Arctic Wolf )A Proud BC Chapter Member
You can check my previous posts, I backed Zip from the start, then he sort of fell off the map for a couple days. Marty's still to be heard from though.
