1977 Autobody Work Help..
Old Mar 28, 2009 | 05:09 PM
Fordmclovin's Avatar
Fordmclovin
Hey guys,
I am stuck. Cant find a new good box up north of you in canada here. So I am going to rebuild it. Cross canada auto parts has everything I need to rebuild this box but not box corners?
I cant find box corners at all, no where. LMC I think has them lower bed panels but not sure if it does the full corner.
Anyways its rotted out pretty damn good and needs a rebuild for sure.
Thanks For Your Time
Cheers
Chris
Old Apr 2, 2009 | 01:47 AM
ReAX's Avatar
ReAX
I seem to remember my 79's bed looked alot like the mid to late 80's van back sides. If you are already cutting and welding, it might be an option to get to you started on the corners.
Old Apr 2, 2009 | 02:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The same sheetmetal was used on all 1975/91 Econolines, with one exception.
The only change occured in 1978, when rectangular headlamps replaced round headlamps, the lower grille panel was slightly different than what was used 1975/77.
Ford did not sell the 1973/79 Styleside bed corners by themselves.
The only way they were available was with the quarter panels (bed sides).
The Styleside pickup beds are essentially the same 1973/79.
The left quarter panel was changed in 1977, but this change only occured because Ford began using fuel doors, instead of having the gas caps exposed.
