What engine was the 71 set up for. If it had a six or a 302 you might have to reposition the motor mount towers. does the 390 come with a tranny. You have to use a tranny from an FE block. You might have to get a different driveshaft. Make sure you get the kickdown linkage with the 390 if you are using an automatic. If you are lucky the 71 came with a 360. If so then it is almost a direct bolt in swap
The truck is a 1971 3/4 ton Explorer. The person I bought it from also received it with no engine. He thought it had a 390 originally.
I believe the auto trans still in the truck is a C6.
This is the vin number if that helps. F25=F250 2wd H=390Cid V8 K=Michigan assembly plant L04430=The remaining six digits are the consecutive unit numbers: your truck was made in November of 1970 at the Michigan assembly plant
Thanks for the replies,
Jeff
So Your 390Cid will bolt directly in as this was the original engine for the truck. a side note to this is Even if you bought a 352-360-410-427-428 they all bolt in
Please excuse the questions that may seem simple. I normally run GM and now joining the Ford community.
I just picked up the motor listed above. I was told was a 390. I never looked at the valve cover label until I got it home. The label says it is a 360.
Is there a place on the engine where I can find numbers to verify actual engine size?
This engine did come with AIR compressor, motor mounts, alternator, starter, exhaust manifolds and a C6 trans.
390 fe truck engines>started in>1968/ in cars ford and 61 t birds was the first 390/4 barrel holly 330 hp.performance eng.option.i put a 68/ c6-390 cs mustang /buckets/consul-floor shifter/> i found under 72 yr.>shifter problems on the tree selector if it had a c4/ fmx > in a 65 -f100 /only put the eng and trans in as a unit as a easier install and the motor mounts/drive shaft is shorter for c6 long tail .put 1 in my 67 -352>merc 250 cs.same adjustments except mounts ok aka "camaro-killer"
My buddy had a factory 390 in his 67 T-bird. That really was a strong motor.
I prefer the new smallblock windsors simply for the weight savings and current range of cheap parts. 351w stroked to 408 is a good performer and reliable as long as power levels are kept 'reasonable.'
Since the engine is out, the best way to tell is to pull the pan and check the crank casting number.
A 390 should have a casting number of 2U or some of the early ones had
C4AE or C3AE.
A 360 will carry a 2T casting.
And to reiterate: They are always 390's when you are buying.
If it is something different post the number and I'll tell you what it is.
Hope for a 1U (428)
