7.3 No Start
Old Mar 28, 2009 | 03:16 PM
toproller's Avatar
toproller
7.3 No Start
My 2002 F350 will crank and crank but it will not start. You can clearly hear the fuel pump starting so i know its getting fuel but it wont start and i have no idea why. Could you guys help me out?
Thanks
Old Mar 28, 2009 | 03:27 PM
ghig1967's Avatar
ghig1967
Thanks
Is the WTS light coming on?
Old Mar 28, 2009 | 03:37 PM
toproller's Avatar
toproller
yea but isnt going off after a while the CES light comes on too
Old Mar 28, 2009 | 03:42 PM
c125bob's Avatar
c125bob
If you can get the codes read that would help a lot. If you can't, make sure you have over 10.5 volts while cranking. Full of clean oil? Somebody else will chime in with some more things to check. Codes reading could save some time and maybe money.
Old Mar 28, 2009 | 03:44 PM
ghig1967's Avatar
ghig1967
I recently had starting issues after my DP Tuner install. it would crank but not fire. Originally someone told me to try a new CPS, but then determined since my fuel pump wasn't kicking in either it was something else. Turned out my PCM wasn't getting power because I pulled a wire loose.
Old Mar 28, 2009 | 03:46 PM
JMac444's Avatar
JMac444
sounds like a cps have you ever replaced it?
Old Mar 28, 2009 | 03:53 PM
toproller's Avatar
toproller
a couple times but not with the new one
Old Mar 28, 2009 | 03:54 PM
F350-6's Avatar
F350-6
If the WTS light stays on, the truck will not start. Nothing to do with the glow plug system. You've likely got a short somewhere. Do you have a chip or tuner? Try checking the wires that come up and over the drivers side valve cover. Wiggle that harness below and behind the square box with the key on and see if the WTS light goes out.
Old Mar 28, 2009 | 04:18 PM
toproller's Avatar
toproller
i do have a tuner but the problem isnt with the WTS light it wont fire it will just crank
Old Mar 28, 2009 | 04:26 PM
F350-6's Avatar
F350-6
I thought you said the WTS light comes on, but does not go off?
Old Mar 28, 2009 | 04:46 PM
toproller's Avatar
toproller
it comes on and doesnt go off but i have started it many times with it on the CES light comes on after a while too
Old Mar 28, 2009 | 04:56 PM
orng1's Avatar
orng1
It needs to go off after 10-15 seconds or else there is a problem somewhere.
Old Mar 28, 2009 | 05:00 PM
F350-6's Avatar
F350-6
Yep, it the light doesn't go off, that's a sign there's a problem with the PCM getting power. If it's a chaffed wire, it can cause a PCM short to ground which will kill the truck or cause a no start condition.
El Camino Man
Oct 4, 2013 07:43 AM
brcwelding
Jan 30, 2012 07:57 AM
Tater50
87
Feb 6, 2011 02:40 PM
40dog
Sep 19, 2008 08:00 AM
cyber1
May 14, 2001 06:50 AM
