Got it running...
Old Mar 28, 2009 | 01:04 PM
maxwelllove's Avatar
maxwelllove
Got it running...
Here's a video of the truck running. Just thought I'd post it in a new post... this is after some modifications (I've been working in it a lot lately) and it seems to sputter around a bit and die. I think it's due to a lack of fuel or wrong carb settings but I made sure to set the float level, and mixture, idle screws right. What do you guys think.
http://www.youtube.com/watch?v=27-kR4aZj2A
Old Mar 28, 2009 | 05:55 PM
maxwelllove
Well I figured it out on my own. Got it running up and down the driveway. Brings up a few more issues though. Someone mentioned that maybe it was because the plugs were fouled by gasoline? What's to stop the new ones from getting like this. I pulled one out after I had it running and the bottom was all black and sooty. This is normal for engine wear correct?
Old Mar 28, 2009 | 07:15 PM
gearhead1952's Avatar
gearhead1952
May be hard to come to a conclusion on the plugs till you have run it for a while but might be running a bit rich.
What did you do to get it running?
Old Mar 28, 2009 | 08:54 PM
maxwelllove
Messed with carb settings, mainly adjusted the float level and the mixture screws but I don't think that was it. I mainly think one of the plugs was fouled. There's a possibility that when I was changing out the wires one of them was loose, but I had checked those before so maybe not. Maybe this didn't do it, I don't know. It's great though, I can take it up and down the driveway without fail.
Old Mar 28, 2009 | 10:53 PM
locomotivebreath's Avatar
locomotivebreath
Save yourself some time and money and invest in a Harbor Freight spark plug cleaner.
