up pipes
Old Mar 27, 2009 | 10:20 PM
dyoung14's Avatar
dyoung14
up pipes
what size pipes should i use to make my up pipes for the psd turbo?
Old Mar 28, 2009 | 11:33 AM
Dave Sponaugle's Avatar
Dave Sponaugle
ATS uses 2.25" ID pipe before the turbo which turns into about 2.5" ID for the up pipe after both manifolds come together into the up pipe.
Small pipe diameter keeps the exhaust moving fast so it spools the turbo faster.
Old Mar 28, 2009 | 12:14 PM
dyoung14's Avatar
dyoung14
on the powerchokes it uses two up pipe like the hypermax pulse setup, each pip runs into a different intrince on the exaust housing
Old Mar 28, 2009 | 12:53 PM
Dave Sponaugle
So you need to run 2.25" ID pipes from each manifold to the turbo exhaust entrance flange.
With the way the manifold pipes clamp on, 2.25" ID pipe is the biggest thing you can get on them anyway.
Old Mar 28, 2009 | 03:24 PM
dyoung14's Avatar
dyoung14
i got some 2'3/8 inch pipe that i will weld to a piece a 2 1/4 pipe that hooks to the manifolds.
