CPS Problem??
Old Mar 27, 2009 | 09:26 PM
ehrig ranch's Avatar
ehrig ranch
CPS Problem??
Back again for some more advice.
I have a 02 7.3, 6speed, 61,000 miles, 6637 filter, gauges (pyro & Boost) 4" turbo back straight pipe exhaust.
On my way home from work today it started missing, (that is acting like a gas motor when a plug wire is grounding, plug fouled, etc.) It did this twice within about a 2 mile span. Check engine light came on and happened approximately 5 more times within last 1/2 mile to house. Cut truck off and restarted, engine light is off and cannot get truck to duplicate problem.
Has anyone else had this problem?
Thanks in advance
Old Mar 28, 2009 | 12:34 AM
adamzelazowski's Avatar
adamzelazowski
Change cps what color you have right now grey or black can you read codes
Old Mar 28, 2009 | 09:47 AM
F350-6's Avatar
F350-6
I agree the CPS would be a good place to start. Get one from Ford or International. We've seen too many issues with the ones from the parts stores.
Old Mar 31, 2009 | 09:53 PM
ehrig ranch
Ran the codes. The computer did not store any.
I went ahead and changed the fuel filter (which I do religiously) and changed out the CPS. I have not had any more problems so far. I have noticed the truck takes longer to start now.
Thanks
