CPS Problem??
I have a 02 7.3, 6speed, 61,000 miles, 6637 filter, gauges (pyro & Boost) 4" turbo back straight pipe exhaust.
On my way home from work today it started missing, (that is acting like a gas motor when a plug wire is grounding, plug fouled, etc.) It did this twice within about a 2 mile span. Check engine light came on and happened approximately 5 more times within last 1/2 mile to house. Cut truck off and restarted, engine light is off and cannot get truck to duplicate problem.
Has anyone else had this problem?
Thanks in advance
I went ahead and changed the fuel filter (which I do religiously) and changed out the CPS. I have not had any more problems so far. I have noticed the truck takes longer to start now.
Thanks
