Sponsored by: Real Truck
Too much heat!
Old Mar 26, 2009 | 08:31 AM
jackofalltrades's Avatar
jackofalltrades
Too much heat!
Cab heat. Temperature control is gone. The fan will turn off/on, the direction control works. The A/C will get cool, but not as fast as normal. I've lost the thermostatic control in my 04.
Where do I start trouble shooting?
-Steve
Old Mar 26, 2009 | 09:06 AM
12ozd's Avatar
12ozd
Heater control valve ?
Old Mar 26, 2009 | 09:08 AM
jackofalltrades
Where is the heater control valve? Is that the vacume controled solenoid at the top of the heater box inside the cab?
-Steve
Old Mar 27, 2009 | 02:41 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do you mean that the hot/cold **** doesn't do anything? That's the blend-door actuator.
Old Mar 27, 2009 | 02:43 PM
jackofalltrades
That is correct, the heat adjust ****/reostat has no effect on the heat being put out. It appears that something's not allowing colder air to be redirected.
Which is the blend door actuator?
-Steve
Old Mar 27, 2009 | 05:12 PM
krewat's Avatar
krewat
On my '01, it was just above the heater box. If you look underneath the dash on the passenger side, just to the left of where the passenger's feet would be, there is an electrical connector there.
When my truck was almost brand-new, it did the same thing. For some reason, the blend door stopped working. I disconnected the connector to it, with the engine running, reconnected it, and it started working. It's worked ever since.
In your case, it's either stuck, or the actuator itself is probably bad.
Old Mar 27, 2009 | 05:15 PM
krewat's Avatar
krewat
From my '01 service manual, maybe the wire colors are the same.
Old Mar 27, 2009 | 05:39 PM
jackofalltrades
Gosh.. Thinking of the vacume controled heating systems in older Fords, and seing the vacume tube at a valve inside the cab at the heater box, Is this what you're calling the Blend Door Actuator? Looks like a vacume line. Not an electrical connector. I'll have to look closer. (looking at your diagram above. Thank you!).. I have to wonder if this could be a blown fuse? Hmm....?
-Steve
sscarboro
Nov 17, 2012 01:16 PM
67nukeford
Nebraska Chapter
1949
Jul 3, 2012 12:58 PM
mwvdub
Wyoming Chapter
268
May 2, 2010 06:56 PM
