6.0 Engine Gasket Set ?
Old Mar 26, 2009 | 08:17 AM
DSMMH's Avatar
DSMMH
I will probably have to replace my HGs but am going to start with the EGR cooler. So when I get a Ford HG set, are all the necessary gaskets required for reassembly with the HG set or is there a separate HG set and upper engine gasket set?
DSMMH
Old Mar 26, 2009 | 08:32 AM
Maxium4x4's Avatar
Maxium4x4
You can buy an upper gasket kit with head gaskets in it. Should have everything you need
