fuel pump question
Old Mar 26, 2009 | 07:14 AM
salty's Avatar
salty
fuel pump question
why does my fuel pump run for 15-20 seconds after shutting down the engine on my 04 F-350? Just curious. Guy I got it from said all of the older model 6.0's do this to prevent fuel from boiling in the injectors?
Old Mar 26, 2009 | 07:46 AM
juneau76's Avatar
juneau76
Their is a thread about this going around right now. Unfortunately, I can't find it to point you to it. There was a flash done to your truck's computer to make it do this to clear the injectors. If I find the thread, I will post it here for you.
Old Mar 26, 2009 | 08:01 AM
salty's Avatar
salty
Thanks!!
any help is appreciated
Old Mar 26, 2009 | 08:11 AM
Maxium4x4's Avatar
Maxium4x4
The fuel pump shouldn't be what your hearing, this is a link to Inductive Heat Flash.
https://www.ford-trucks.com/forums/8...eat-flash.html
69cj's Avatar
69cj
You have what's called the buzz flash to clear the injector spools of oil. There is a later flash called the inductive flash that does that at start up thru electrical induction thus eliminating the buzz. The later flash also exercises your turbo and varies rpm's after X amount of idleing.
Old Mar 26, 2009 | 08:36 AM
salty's Avatar
salty
so which flash is recommended?
Old Mar 26, 2009 | 08:42 AM
69cj's Avatar
69cj
The inductive is considered better because it exercises the turbo.
salty's Avatar
salty
how much does it cost to get this done?
Old Mar 26, 2009 | 01:04 PM
69cj's Avatar
69cj
Depending on the dealer usually about an hour of labor.
