Battery keeps going dead.
Old Mar 25, 2009 | 02:25 PM
zoomer's Avatar
zoomer
On my 71 f100, the battery keeps going dead after a few days of sitting. Nothing is on in the cab. I've replaced the alternator, and regulator. I've disconnected the ignition switch and it still died.
This morning I had to drive it to work so I hooke the pos. battery cable back up. (It won't die this way) And when I cranked the truck I noticed the right turn signal indicator on the dash was on. Not flashing just on. I turned on the right signal and turned it off, it didn't go completely out, it just glowed. When I reved the truck up, it dimmed. Anyone know anything about this? I'm thinking it has something to do with the drain but just not sure how to hem this up.
Any help is greatly appreciated.
Old Mar 25, 2009 | 03:19 PM
Freightrain's Avatar
Freightrain
Sounds like maybe a turn signal switch problem?
Try this, reach under the dash and unplug the harness going up the column. Does the light go out?
If not, unhook the battery, put a test light between battery and cable. It should glow as there is a draw on the system. Now start pulling fuses and see what causes the test light to go out. This will narrow down the search.
Donnalee
Jun 16, 2016 09:32 PM
52' fordnut
23
Jan 15, 2016 12:33 PM
52' fordnut
Jul 21, 2015 10:07 PM
Fameus
Feb 27, 2013 02:17 AM
MyName1sMud
39
May 11, 2012 09:41 PM
