Sponsored by: Real Truck
Replacing front pads
Old Mar 25, 2009 | 12:57 PM
Headviking's Avatar
Headviking
Quick question. Will I need to bleed my brakes if I just replace my pads?
Old Mar 25, 2009 | 12:59 PM
jamie7375's Avatar
jamie7375
I just did the pads..Just dont open the res or the lines and you are set...
Old Mar 26, 2009 | 02:40 PM
mikesmayhem's Avatar
mikesmayhem
You may have to take resevoir lid off to allow for room for the fluid once you compress the calipers, but that doesn't mean you will need to bleed.
Old Mar 26, 2009 | 03:01 PM
03_PSD's Avatar
03_PSD
no bleeding required
Old Mar 26, 2009 | 03:07 PM
jim henderson's Avatar
jim henderson
You won't need to bleed unless you let the fluid get too low in the reservoir or you open the valves.
BUT, You should periodically bleed and flush contaminants out of the system. If the fluid is brown, flush(Uh bleed) it down.
Dirty fluid can lead to rust of the system(cylinders, lines etc) and bad braking after a long stop. If you ever rode your brakes down a mountain, you may have discovered the fun of a spongy brake pedal. Dirty fluid makes this happen easier.
So yeah the lazy brake job is Ok without bleeding. But a good brake job includes bleeding and flushing.
Good Luck,
Jim Henderson
Old Mar 26, 2009 | 05:03 PM
mwsF250's Avatar
mwsF250
As they said, nope. Just make sure there is room in the reservoir when you push pistons back in and fluid upstream.
Maintenance schedules for "non disposable" vehicles recommend flushing brake fluid every 2 years.
Old Mar 26, 2009 | 08:23 PM
Antelope V-10's Avatar
Antelope V-10
I'm doing mine tomorrow. I was going to open the bleeder then push the piston back in. Changing out some fluid is one reason, the other reason was I thought you didn't want fluid going back towards the master cylinder on ABS brakes. Any thoughts?
Old Mar 26, 2009 | 09:49 PM
Alta's Avatar
Alta
Rather than open the bleeders, just use a big C clamp and gently slide the caliper back, then un-bolt, pop in the new pads, re-assemble and yer on yer way. No mess, no bleeding.
Old Mar 26, 2009 | 10:54 PM
dstig1's Avatar
dstig1
Antelope V10 has the correct procedure (and reason). Then when you have the new pads in and everything back in place, do a quick bleed on each caliper in case any air got in. Not much trouble to do and well worth the minor effort.
I would also flush (bleed) the whole system. I do it at least once every 2 yrs on all my cars. But the real important part is above.
-Dave
Old Mar 26, 2009 | 11:58 PM
flamebuster's Avatar
flamebuster
Agree with Antelope v10
