Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Help with changing rotors
Old Mar 24, 2009 | 08:07 PM
Lindy in Dryden's Avatar
Lindy in Dryden
Hi Everyone,
I am trying to replace the brake pads and rotors on my 03 Ford escape but find it impossible to remove the rotors. Is there something that I am missing? I have tried pullers and a rubber mallet but no luck? Please help.
Thank you
Lindy
Old Mar 25, 2009 | 01:24 AM
bmuhlbach's Avatar
bmuhlbach
they rust on I took a cut off wheel on my body grinder and cut a pc off between 2 studs and center hub and then it came right off
Old Mar 25, 2009 | 04:36 AM
Dan Robertson's Avatar
Dan Robertson
Sometimes they can be a real bugger to get off. Bigger hammers, grinders, even torches are sometimes needed. When you do get them off, you can make future repair jobs easier by using a liberal amount of never seize lubricant on the hub where the rotors make contact. Up here where I live (Northern Maine), it is the road salt that causes the corrosion problem. It causes real havoc on drum brake hardware too.
Old Mar 25, 2009 | 06:07 AM
Lindy in Dryden
Thanks guys,
It sounds like I need a bigger Hammer and a whole lot of persistence.
Yup lots of road salt here in N.W.Ontario as well.
Lindy
Old Mar 25, 2009 | 09:50 AM
bmuhlbach's Avatar
bmuhlbach
I beat on mine for a while with a very big hammer. cut the wedge out lots easier and faster
Old Mar 25, 2009 | 07:51 PM
Lindy in Dryden
Thanks guys,
A big hammer and about 5 minutes of beating on it did the trick. The passenger side came off much easier.
Lindy
lindy87
Jun 17, 2014 02:40 PM
TheHoff884
May 11, 2012 11:36 AM
Lindy in Dryden
1997 - 2003 F150
Dec 31, 2008 07:05 AM
Lindy24
Nov 25, 2006 01:13 AM
JohnT
Illinois Chapter
17
Feb 10, 2005 12:59 PM
