Towing Package ???
Old Jul 11, 2002 | 02:11 PM
Rbomar's Avatar
Rbomar
Towing Package ???
How can I tell if my 95 Explorer Sport has the towing package? It was bought used but has a hitch and wiring harness. Hummmm !
Old Aug 8, 2002 | 02:51 PM
hitecdan's Avatar
hitecdan
Towing Package ???
Generally you can tell by looking to see if there is a Ford installed aux transmission cooler installed, a 3 or 4 row radiator and taller gears in the rear diff, one of the larger engine options avaiable for that vehical, things like that. You may want to do a little research and see if Ford even offered a tow package for those two door Exploders. Regardless, look at the sticker on the driver’s side door jamb, it should list your max GVWR (gross vehicle weight rating) as well as the max GCVWR (gross combined vehicle weight rating). Subtract the GVWR from the GCVWR and that should give you a rough idea of how much you can tow.
Old Aug 10, 2002 | 09:48 AM
red ranger's Avatar
red ranger
Towing Package ???
