torq specs
Old Mar 23, 2009 | 09:12 PM
KRAZY KRAMER's Avatar
KRAZY KRAMER
torq specs
first off, i just want to say this site is great, and everyone on here is a great help. i dont really have time to get on the computer much, but when i do i try to help anyone on here anyway i can because i know everyone else on here would do the same..... this question is a relativley easy on, well at least for someone with a good memory or a manual haha..... does anyone know what the 6 bolts holding the flywheel to the crank should be tightened to? also the 6 bolts holding the pressure plate to the flywheel?
the truck is a 91 f150 with the 5.0/302
thanks for all the help in advance!
KRAMER
Old Mar 23, 2009 | 09:18 PM
wickedklown83's Avatar
wickedklown83
flywheel bolts are 75 to 85 foot lbs pressure plate to flywheel is as follows
10inch disc 15 to 20 ft lbs
11inch disc 20 to 29 ft lbs and
12inch disc is 15 to 20 ft lbs
Old Mar 25, 2009 | 08:06 AM
KRAZY KRAMER
thanks wicked...appreciate the help... i seen you are having some troubles with an older pre-power stroke and you are in pa? roughly where are you in pa? haha you dont have to give me a town or your home address, just wondering how far from south jersey you are
Old Mar 25, 2009 | 10:42 AM
Nitramjr's Avatar
Nitramjr
If I remember correctly, I think you are supposed to put some thread-lock on the bolts holding the flywheel on. Worth looking into I would think.
Old Mar 25, 2009 | 10:50 AM
KRAZY KRAMER
you deff need to put some on there, thats for sure..you can even see the thread locker on the bolts from the factory when you pull them out....thanks for keeping an eye out ray
