96 explorer
Old Mar 23, 2009 | 08:47 PM
3rd car's Avatar
3rd car
96 explorer
i have a 96 explorer and i was woundring if the relay for locks is bad b.c my door will not lock from the button on the door or from the remote but will unlock and from the remote and from the door the button in the trunk will lock and unlock the door i was woundring if u guys think this is the relay or something different
Old Mar 24, 2009 | 08:30 AM
noboston's Avatar
noboston
look for a broken wire in the door cable ,in the rubber boot between the door(drivers side) and the piller,pull the boot back and look for wire pink/yellow tracer also a,pink /lite green tracer .give these wires a thug to see if they are broken inside thier insulation .
Old Mar 26, 2009 | 05:23 PM
3rd car's Avatar
3rd car
i did pull it off i didnt see any broken wires it was hard as hell to see
Old Mar 26, 2009 | 07:02 PM
aquanaut20's Avatar
aquanaut20
looking is not god enough either put strain on each wire or us a VOM. Common problem, have fixed many.
Old Mar 26, 2009 | 07:09 PM
noboston's Avatar
noboston
try swaping the lock relay with each other ,and see what happens .there are 3 lock relays over the drivers side wheel well. open the jack compartment and up over the wheel well you will find the lock relays .see if they all operate ,place your hand on each and have some one operate the switchs and remote .one relay is for the drivers lock and one is for all unlock and the other is for all other lock. in front of the relays is the remote anti theft personality module (rap)
Old Mar 26, 2009 | 08:20 PM
3rd car's Avatar
3rd car
the remote will turn the alarm on and when i hit the last 2 button on the keypad on out side of door alarm will turn on but only time it will lock if done manuall or by button in trunk
Old Mar 27, 2009 | 08:52 AM
noboston's Avatar
noboston
check thread (last post) on AC97 follow that test.
