Clutch Master Cylender help!!
Old Mar 23, 2009 | 07:15 PM
hayden01's Avatar
hayden01
I have a '84 Full Size Bronco with the hydrolic clutch and I need to know how hard it is to replace it with a new one.
It is leaking like a faucet on full blast. I tryed J.B. Weld and it still leakes like a sive...SO any help on this one? Is it a supper hard job or is it an ok job?
Thanks
Old Mar 24, 2009 | 06:19 AM
Lazy K's Avatar
Lazy K
This is the master cylinder on the firewall, right? If so it is an easy job. Once the new one is on you will have to bleed some fluid through the line and out the bleed screw at the trans. and that`s it.
Old Mar 24, 2009 | 08:01 PM
hayden01's Avatar
hayden01
Alrighty, you were right it was easer then I though to put a new one in. Now bleading the clutch line brought up another question....were is the bleed screw? I can't find it on the slave cylender any were....any pointers?
Old Mar 25, 2009 | 05:57 AM
Lazy K's Avatar
Lazy K
Look for a small allen screw, if you find it use that. Otherwise try this, pump the pedal several times then get under and push the cylinder piston fully in to push fluid back up to master cylinder. Doing this a few times should work.
