Sponsored by: Real Truck
4x4 no worky?
Old Mar 23, 2009 | 06:30 PM
RckyMntnKng's Avatar
RckyMntnKng
4x4 no worky?
Well I ran into a huge snow-melt mud patch in a field this weekend and needed to use 4 wheel drive.
Got out and locked the manual hubs and when I pulled the lever inside I heard a "Ker-whunk" sound. I chocked it up to the normal sounds and went on out into field.
Needless to say i had no 4x4 and got stuck. Later that same weekend I also had to dig out of a snow-bank with no 4x4.
Big diesels wont push themselves down-hill in ice or mud without weight in the back and/or 4wheel drive.
Any ideas on what that sound was and what I should look for?
I assume I broke something in the transfer case.
Thanks-RMK
Old Mar 23, 2009 | 07:44 PM
pjwoolw's Avatar
pjwoolw
Drain the fluid and see if anything other than fluid comes out.
Old Mar 24, 2009 | 07:51 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Gotta see what's working and what's not.
With the hubs locked, and the transfer case in 4x2 (2-wheel drive), try to turn the front driveshaft by hand. If it won't move, then the hubs are working.
Then, unlock the hubs, and test again, driveshaft should spin.
Then, put transfer case in 4x4 and see if front driveshaft spins.
ALSO - check 4LOW. If the driveshaft still spins even in 4LOW, that's pretty bad.
Old Mar 24, 2009 | 09:24 AM
RckyMntnKng
Thank you gentlemen, I will try this tonight and report back.
Old Mar 30, 2009 | 12:18 PM
RckyMntnKng
Test Results...
Transfer in 2x4 and hubs locked, I can spin the front driveshaft by hand. The u-joint on the driver side doesnt turn, but the passenger one does.
Think my transfer case is ok, but the hubs / axle is broke
Old Mar 30, 2009 | 01:02 PM
krewat's Avatar
krewat
Most likely the hub is not locking or or the locking ring is broken, I doubt the axle is broken.
Might be time to go with Warns or Mile Markers.
Old Mar 30, 2009 | 01:53 PM
RckyMntnKng
I agree, thanks very much for steering me towards the solution.
