I was a bit nervous with all of the sensory voodoo of this brake controller. What a great, smooth , operation. Thanks for the recomendation. By the way I did get it at that web site with the free shipping. No hassle.
http://www.brakecontroller.com/ The way this thing applies the juice to the trailer is unbelievably smooth . It senses load via momemtum and applies the correct amount of voltage to the brakes for that situation. This is no means a technical briefing but just my simple interpretation.
The Prodigy is simple to set up and once you do, you never have to think about it again.
It works so well, I can't believe I put up with the old style hydraulic/electric controllers for so long!
I switched to the Prodigy last year, after reading so many enthusiastic reviews about it in this forum.
>Better than the hydrolics?????
>say it isn't so.
>I love the old style that hooked into your hydrolic brake
>sys the harder you pushed on the pedal the more trailer
>breaks you had.
Same effect. The harder you stop, the more trailer brakes you have. BUT, no need to hook anything into your hyd brake lines! Very slick.
