Sponsored by: Real Truck
Changing fuel filter
Old Mar 23, 2009 | 10:59 AM
myonlytruck05's Avatar
myonlytruck05
Just getting ready to try doing a few things myself on my 05 SD with 5.4 V8. Not much of a mechanic but thought I could change the fuel filter myself. I have the tools needed and looking for any help as far as not getting fuel all over and up and down my arm, etc. Any ideas and hints would be appreciated. Thanks for any help and Thanks for all the info I do get off this site. It is really helpful.
Old Mar 23, 2009 | 12:56 PM
jim henderson's Avatar
jim henderson
I do not know your model but in general, you will want to let the fuel pressure bleed off and you probably need the special tools to remove the filter.
The fuel pressure can be bled off just by letting it sit overnite or so. Or you could go to the fuel rails and release the pressure thru the valves there, but you may get some spray. I usually let it sit on a weekend and do it after a day or two.
In ALL cases have an extinguisher handy so your partner can put you out if worse comes to worse. All it takes is a stray spark including static.
On my 94 F250, the filter is located on the right side/passenger frame. It can be a beach to get enough leverage with your hands, so paitience and a lot of squirming may be needed. I think I use a flat head screw driver for leverage, but be careful about denting the filter.
The fuel filter tool is usually sold in sets. They look like fat plastic Poker Chips with a hole in the middle and a collar around the hole. They slide under the filter collar to release the spring loaded lock. I don't think you can easily remove the filter without one of these tools. They are cheap. I paid something like $5 10 years back for my set.
Have a drain pan handy, and said extinguisher, and release one of the filter locks and let any gas dribble into the pan. Release the other lock and either plug the hose with a bolt or something or aim it upwards to minimize leakage. When doing my truck, I get maybe a cup of gas dribbling into the pan.
Putting the new filter in can be a pain due to the mentioned tight space. Hard to get enough pressure on things to push the hose back into the new filter. Also some filters(maybe all?) are fairly thin skinned so they will dent if you force them too much.
Maybe a 15 minute job if you can get leverage. Half an hour if to have to work hard at it.
Good Luck,
Jim Henderson
Old Mar 23, 2009 | 01:09 PM
rebelyell618's Avatar
rebelyell618
first, tools.. as jim said is correct.. the white clips is what i used, but there are couple other styles too. i used a 3/8 on the white clips.
i let the pressure go down by leaving the truck sit overnight and did the filter removal that afternoon.
https://www.ford-trucks.com/forums/5...el-filter.html
here is a good and kinda humorous way of getting the filter off..
https://www.ford-trucks.com/article/...0_Pickups.html
here is one for a F150, pretty much the same process as for your 250 though.
and if you a visual person here is a video from youtube when they changed one of a E350 i believe...
YouTube - How to remove a fuel fliter
hope this helps you out.
Old Mar 23, 2009 | 09:05 PM
dstig1's Avatar
dstig1
The '05 should not require special tools - it's a squeeze release fitting on the filter on mine (sounds like the same truck as yours). You push the blue or white band in and pull. Bleed the pressure FIRST by starting the truck and pulling the fuel pump fuse (#40 under the dash). It'll die fast. Filter is inside the driver's sideframe rail, under the cab. Then you need to unbolt the fuel filter carrier to get extra room to work. The flexible portion of the lines are waaay too short to allow enough flex room to get the filter out, so it's a bit of a PITA. Keep a cup or pan handy to catch the gas that will come out. A cup or 2 worth. Had they designed the filter connection a little smarter, it would be a lot easier, but it's really just a bit annoying.
After getting the new filter in turn the key to run (not start) a couple times to get the fuel pressure up before cranking or you will crank for a long time for no good reason. You can hear the fuel pump change tone clearly when it gets up to pressure.
-Dave
usmcknight69
Oct 13, 2011 09:19 AM
Rays 2010 F250 6.4L
May 26, 2010 12:05 PM
QPS
Mar 9, 2009 02:06 PM
aphotic26
Dec 11, 2008 02:39 PM
