Guys, my 94 F150 has the gauge cluster with no tach. Is it possible to switch gauge clusters and retain the correct mileage? Or is it possible just to switch them?
i just did this to my 93 f150 all you need to do is pry the oil and temp gauge out first and then the fuel and volts gauge out. the speedo is last. do the same to the new cluster . then you put your original speedo in the new new cluster and then the tach and the fuel and oil gauge then the temp and fuel gauge. and then just put it all back in the truck. hope this helps!
