Hello every one,
I know this should be posted in the super duty forum but I like this one a lot better.
My friends 95 all of a sudden the blinker don't work. The lights on the dash don't work or on the out side. We have not checked anything yet but any one have a place to start?
Thanks
Nick
On my 99 when one of the brake lights went bad, nothe the low just the high filament it did that too, check your bulbs they use a feed loop. That and I think theres independant fusing for the left and right side in the fuse box under the hood. Last but not least what does it matter they give you 2 lights so you have spare right?
Could be the multifunction switch. Wipers,turn signal etc. Easy to change and u can get them at a junkyard. Bronco, Ranger, F150 they are all the same. Hope this helps.
My 96 had the same problem the turn signal switch was the problem easy fix I just sprayed some electrical contact cleaner and moved the turnsignal arm up and down.It was fine after that hope that helps
