front add-a-leaf ?'s
Old Mar 22, 2009 | 10:02 PM
96F250tat's Avatar
96F250tat
I recently decided that i want to put a set of add a leafs on the front of my 96 f250 to hopefully level her out (and maybe add some 35's this summer ). she sits about 2.5 inches higher in the rear because of an add a leaf and airbags. I was just wondering if anyone has any pics of their trucks with front aal's. and which brands would be the best. I was lookin at front aal's by superlift and skyjacker from summit? plus would i need longer u-bolts, cause they dont say anything about them? thanx for any help in advance!
Old Mar 23, 2009 | 08:01 AM
Baja16's Avatar
Baja16
subscribed... lookin to do the same with my 96' F-250
Old Mar 23, 2009 | 08:08 AM
BTSNPCS1990's Avatar
BTSNPCS1990
I'm watching this too because I need to do something with my 92 also. I have 33's on it and the front tires will touch the bumper when turning in reverse. I already trimmed a little off the bumper on the inside to clear going forward.
Old Mar 23, 2009 | 02:24 PM
96F250tat's Avatar
96F250tat
yea hopefully someone will chime in here. i also posted this in the 4x4/offroad forum as well
Old Mar 23, 2009 | 04:33 PM
guitarnik's Avatar
guitarnik
i put AAL on the front of my 90 f250, i used rough country dont use them it was supposed to raise it 2.5" but it only raised it 2" and 2 months later im back to only a 1" lift. i would order some from skyjacker or superlift or even get some from a local 4x4 shop. also buy or order the biggest camber bushing set you can if youve got the TTB front end. if you put it on yourself it shouldnt need to be re-aligned right away( if you also put the cam set on at the same time) but i would after a few eeks when the springs settle.
Old Mar 23, 2009 | 04:39 PM
Rulebreaker's Avatar
Rulebreaker
Put some cab chassy leafs in and then go see your dentist. RB
Old Mar 23, 2009 | 07:10 PM
96F250tat's Avatar
96F250tat
yea i havent heard any great comments on rough country quality. did u have to use longer u bolts as well?
Old Mar 24, 2009 | 05:21 PM
Jeff Dodson's Avatar
Jeff Dodson
I have the truck you are lookingt for, The only thing is , I can never remember how to post the pics. Its the truck in my signature. It is a 97 F250 4x4 with AAL in front and 2 in blocks in rear.
BTW it rides like a tank, but OH WELL, its mine
Old Mar 24, 2009 | 05:28 PM
guitarnik's Avatar
guitarnik
no the stock bolts are oong enough
Old Mar 24, 2009 | 05:31 PM
Jeff Dodson
Mine was a factory/Dealer installed lift, as far as I can tell it has not sagged at all. What kit they used I could not tell you.
