6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What a tow!
Old Mar 22, 2009 | 05:37 PM
walquist1's Avatar
walquist1
What a tow!
Took our 9,000lb 5th wheel out this weekend with my new F-250 crew cab, long bed 6.4L diesel for the first time. Hit the on-ramp and barely knew it was behind the truck. This new truck is awesome. Had to pass a little ole lady in a minivan, touched the gas pedal and was around her in seconds.
The power is amazing. Mileage was excellent also. Won't go back to gas ever again.
Old Mar 22, 2009 | 06:10 PM
ruschejj's Avatar
ruschejj
My sentiments exactly. You can add another 5,000 lbs. to your 5th wheel and still wonder if it's behind you in these trucks.
Old Mar 22, 2009 | 06:23 PM
senix's Avatar
senix
I agree! it is amazing. I did this load with 600 miles on the truck. 900 mile round trip. 10K lbs.Pictures by senix_2008 - Photobucket
Old Mar 22, 2009 | 06:34 PM
RedRage's Avatar
RedRage
I've towed with a Dodge diesel and I can tell you the Ford is by far the better towing machine. That 6.4 is a towing monster!
Old Mar 23, 2009 | 12:34 PM
sdrono's Avatar
sdrono
So no major drop in milege from no load to load? I have an 08 F350 dually 4X4 with 4:10s that is Job 3 and latest flash with 2800 miles and at 70 mph only get 11.6 to 12.6 mpg. I'm hoping for it to get better w/o load because this summer I will be towing a 10K 5th wheel along with a 3K boat and with my 05 F250 I got 9-10 mpg and somtimes 11 mpg (no wind) @ 65-70 mph. I went to the dually for more stablity and possible flat tire protection. The F250 had 3:73 gears. Any thoughts?
Old Mar 23, 2009 | 04:54 PM
thatsme's Avatar
thatsme
Same exact truck as you. 10 to 12 with 10,000 lbs. 5th-wheel & 15 to 17 MPG. unloaded on the HWY. Got to keep her at 2000 RPM's , 62 to 63 MPH. to get the 15 to 17 unloaded. I have a job #2 truck w/10,500 miles on it. Planning on getting latest flash done here soon. BTW wait until you tow with it, you won't even know you have a load behind you, it is awsome.
Old Mar 23, 2009 | 05:57 PM
walquist1's Avatar
walquist1
Mine is a job 2 and a 4X2. I paced it around 60-65 and was getting about 11.5 mpg loaded. If I keep my foot out of the gas pedal (which is hard to do) I get 15-19 on the interstate. Used less than a quarter tank of diesel for the 110 mile towing round trip this past weekend. My previous gas 5.4L F-250 burned a 1/4 tank there, 1/4 tank back.
My truck has the camper package add-on, so when I set the 5er down in the bed, the truck didn't even move. Forget the bilsteins or whatever.
A few of you state your mpg's are worse after the latest reflash. Maybe I'll just leave my truck alone.
I am blown away by the towing power of this truck and response when needed. Shoulda bought a diesel long ago.
