wtf
Old Mar 22, 2009 | 05:31 PM
dougf2504x4's Avatar
dougf2504x4
wtf
i have a 88 2504x4 5.8L c6 and the vacuum modulator when i pulled it out to change the new one had alot of tranny fluid comming out is this normal and ok or is the tube that runs inside the trans bad? help thnx
Old Mar 22, 2009 | 05:47 PM
1966Tbird's Avatar
1966Tbird
that's normal
Old Mar 22, 2009 | 08:40 PM
dustybumpers's Avatar
dustybumpers
it's normal, but if you have trans fluid on the vaccume line side the modulator is bad
Old Mar 22, 2009 | 08:49 PM
dougf2504x4
it wont go in 1/2/or D but it will go in reverse when i get it to go in 1/2/D i have to hit the gas hard to even get the truck to move any ideas?
Old Mar 22, 2009 | 09:24 PM
1966Tbird's Avatar
1966Tbird
same thing happened to me when i had a 66 transmission (c6) with a 67+ reverse full manual valvebody in it...needless to say i fried both the transmission and the valvebody in about 20 feet
Old Mar 22, 2009 | 09:36 PM
HrdDrv's Avatar
HrdDrv
Check the vacuum to the modulator. My '71 had a clogged line from the manifold, and wouldn't get out of 1st gear.
