changing clutch switch
Old Mar 22, 2009 | 03:11 PM
octaneforce's Avatar
octaneforce
how would i go about replacing the clutch switch on a 1992 f150 5spd with the i6 motor? im pretty sure the switch is shot unless there is some way to adjust it? anyway, does it come apart, or do i have to find the end of the rod to slide it off?
Old Mar 22, 2009 | 08:05 PM
octaneforce
oh, and what should i look to be paying for this part if my local junk yard has it?
Old Mar 22, 2009 | 09:09 PM
MatCat58's Avatar
MatCat58
The easiest way I found to get it off is to unbolt the master cylinder, then there is a white plastic piece that you slide backwards and it comes right off the pushrod. It'll make more sense when you have it in your hand. Also, unplug the harness before you try to pull the master cylinder through the firewall.
Old Mar 29, 2009 | 05:20 PM
octaneforce
could somebody show me a schematics of this part of the truck? its 1 92 f150 btw. i6. -thanks
Old Mar 29, 2009 | 07:27 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It is easy to adjust.
Just slide it up the toothed rod so that the next time you depress the clutch it adjusts itself.
I'm sorry but all my CD manuals are packed away at another location.
Old Mar 29, 2009 | 10:46 PM
F150xlt's Avatar
F150xlt
Here's a pic. of the clutch safety switch.
You need to pry the plastic retainer off. The switch can then be pushed off of the clutch push rod.
The second pic. shows the wiring for the clutch switch from a 88 manual. Don't know if the wire color codes are the same as your 92 but the switch it self is the same.
