Conversion to 4WD
Old Mar 22, 2009 | 02:49 PM
sandhill's Avatar
sandhill
Conversion to 4WD
Hello All. Have a 1996 2WD F-150 5_spd six. Want to convert to 4WD. I have a 1989 4WD. Both Manuals, reg cabs, same gearing, same tire size, both xl, both rear abs. Other than couping with different type of speedo signal, is the swap difficult (ps 89 is a 302)
Old Mar 22, 2009 | 05:32 PM
Kahuna's Avatar
Kahuna
It is completly bolt in your dash even has the 4x4 light allready in it.Only mod is cutting the hole for the T case shifter.
Old Mar 22, 2009 | 05:50 PM
1966Tbird's Avatar
1966Tbird
you don't have to mess with the speedo signal since you can use the same rear which is where your 96 gets the signal just get some wire cutters and cut the speedo cable off and leave it in the trans/transfer case as a plug
jonmammenga
Nov 7, 2014 09:26 AM
zakt
Apr 7, 2013 10:58 PM
jjoel
1997 - 2003 F150
26
Mar 11, 2013 07:36 AM
DaytonaTunnel
Jan 7, 2011 02:20 PM
