Muffler Delete Question
Which year and motor....
To each his own....
but have you heard one without a muffler?
I tried it on my 03 and NO WAY would I do that again - way too much drone
I did the Walker BTM muffler for about $60 @ Napa and have a good sound with good flow... and no drone
Good luck !
Noise is a big thing where I live. From fart piped compacts to diesels without muffled stacks, they all get pulled over if too loud or even if they hint at being too loud. (Probable cause) It doesn't take much for these guys to know who has modified exhaust and who doesn't. It's probable cause for them to stop you. Might just inconvenience you as they may not write a ticket. I don't think they carry sound meters around with them. But they could order you to get it tested and bring the results to the judge.
its a different story - but only outside...The trucks appear much more tolerant of the 'drone' the the X's. I just had a friend in my F350 last nite who did not believe my truck had no muffler!
If you are such a ***** that an officer WANTS to give you a ticket for loud exhaust - SHAME ON YOU!!!
1) I am not overwhelmed with confidence that govt employees in general, and motor vehicle dept. officials in particular, have ANY brains or technical competence. But you say "many states consider a turbocharger a muffler" ? I HOPE you are wrong. I HOPE the stupidity of govt. employees hasn't gone THAT far. Can you cite me which state's vehicle code claims a "muffler" is a "turbo-charger"..?
2) A good old saying about freedom is "your nose ends where mine begins". That is why many states, possiblly most, if not all state's vehicle codes provide for limits on how much noise you can make.
There is a mistaken belief amongst some amatuer non-technical trained "backyard" mechanics that NO back-pressure is somehow a good thing. This was not true in the old days - plenty of articles in the SAE tech. journal about the necessity of SOME back-pressure for max. effiency.
These days there is a new factor as to why monkeying with today's vehicle's exhaust system may be a bad idea, as well as a violation of federal law - computer-controlled anti-pollution devices. Both state and fed. codes prohibit interferring with anti pollution devices.
I have no idea what effect, if any, "gutting" the exhaust system would have on the modern computer-controlled vehicle. Dont want to find out.
I agree we dont want too much interference in what we can do to our own private vehicles. But again - remember where your freedom ends. At my ears and eyes and nose !
The reason I suggested some of you fellows do some research on this issue, is the same as what i suggested about much more powerful headlights. Same problem. Extra noise may prevent you or others from hearing safety issues. Overly bright headlights may blind and thus cause an insafe condition for other cars.
In either case, in some states, you "pull" that stuff when a law enforcement official is around, he may have the power under that state's vehicle code to impound your vehicle right then and there, call for a tow, and then you are faced with being at the mercy of local businessmen, when you are told it can not be released to you to go back on public roadways until it meets legal standards.
It's the old story about common sense and GOOD MANNERS being the best approach.
personally i drive a gasser and my work truck is a cummins with a bully dog exhaust so i never went searching for answers to find out the true meaning, but this is the law.
Texas Department of Public Safety - Inspection/Rejection Criteria
20.15 Exhaust System. Every motor vehicle shall at all times be equipped with muffler in good working order and in constant operation.
Muffler defined: Muffler is a device consisting of a series of chambers or baffle plates or other mechanical design for the purpose of receiving exhaust gas from an internal combustion engine and/or turbine wheels for the purpose of receiving exhaust gas from a diesel engine, both of which are effective in reducing noise.
The exhaust system includes the manifolds, gaskets, exhaust lines, mufflers, resonators, tailpiping, and supporting hardware.
Motor vehicles cannot be equipped with a muffler which is perforated or which was perforated and has been repaired, either by a muffler repair jacket or by patching or in any other way. In those cases where a muffler is perforated at the time of an inspection or has been perforated and has been repaired previous to the inspection, the muffler must be replaced or the vehicle rejected.
Some pickups are equipped with a camper or hard shell cover and are sometimes used for the transportation of passengers. The tailpipe should discharge the exhaust at the rear or sides. This truck modification will be considered as a passenger compartment.
The entire structure of a motor home-type vehicle is considered a passenger compartment. The cab only of all other truck-type vehicles is considered passenger or luggage compartment.
If the vehicle is equipped with lake pipes or similar devices, such pipes or devices must be securely plated and bolted or capped.
Dual exhaust systems may be modified to single exhaust systems and single exhaust systems to dual exhaust systems, provided the modification does not violate requirements concerning exhaust emission systems.
The catalytic converter will be considered as a part of the exhaust system on all vehicles prior to 1984 year model and will be inspected only visually (if present) for leakage. On 1984 and later model light truck and passenger vehicles, the catalytic converter will be checked for presence and leakage. Flexible tubing which meets the requirements listed below may be used anywhere in the exhaust system.
Most heavy trucks have their exhaust facing vertically, so the most irritating sound waves head skyward.
Bottom line - as I suggested - a little common sense and courtesy makes life easier for everyone.
