I have removed part of my door panel on my 97 ranger and i cant get it off because of the the manual window crank and i dont know how to take the crank off and if i get the crank off i can get the panal off to instal my new speakers so i need some info
Pry harder! But only at the "base" of the crank. Like BigRig said, it will stay connected at the other end, and you can swing the plastic out of the way of the Torx screw underneath.
If you haven't already found it, there is one screw at the bottom-back of the door panel. If you have carpet down there, it's hidden pretty well. After all the screws and the window crank are out, lift straight up on the panel and it should come loose.
