5th wheel
Old Nov 18, 2002 | 09:54 AM
maddep15's Avatar
maddep15
Post 5th wheel
I am new to this and am sure I will be repeating someone. I am interested in putting a 5th wheel hitch in a 2000 F150 4x4. #1 How hard is it for a do-it-yourselfer and #2 I have a tool box and will it have to be removed before towing, say a camper. Thanks for any info.
Old Nov 20, 2002 | 01:52 PM
CmprSpecial's Avatar
CmprSpecial
5th wheel
If you are a good welder, it's pretty straight forward.
Old Nov 21, 2002 | 07:53 PM
theonlybull's Avatar
theonlybull
5th wheel
good welder?? most 5th wheels are bolt in afairs, not weld in.. most are fairly simple to do with a few tools and some knowlage.
Old Nov 22, 2002 | 12:59 PM
CmprSpecial
5th wheel
I admit I have only see a few 5th wheel installations, but all of them had the brackets that mount to the frame welded to the frame, including mine. I looked at the Reese web site and indeed their instructions indicate a bolt in installation.
That being the case, I guess it should be fairly easy.
Old Nov 22, 2002 | 04:47 PM
fullerhg's Avatar
fullerhg
5th wheel
>installation.
Now -- about the toolbox: you'll have to remove if it is an above the bed type and if you pull a 5th wheel, no if you pull a camper.
Old Nov 23, 2002 | 09:35 AM
70spoiler's Avatar
70spoiler
5th wheel
do not weld to your frame!!look and see if ford welded anything on the frame.it is all rivited and bolted.installing a hitch is pretty easy.if you need to give me a call and i will help you out.most people are not that good of welders,you can undercut the weld,get no penatration,trap slag ect...and most of all ruin the metalurgy of the frame itself.i do a little welding and am certified in many weld procedures.just bolt it.jack k
Old Nov 23, 2002 | 10:59 AM
flyboy2610's Avatar
flyboy2610
5th wheel
Agreed. Do NOT weld to the frame! You will destroy the temper of the steel. If you look at the frame of a class 8 truck you will see a label warning against welding to it.
If you feel you must have your hitch welded, have it done at a certified frame shop.
Old Nov 24, 2002 | 09:32 PM
ImxNavy's Avatar
ImxNavy
5th wheel
My son & I installed a 5th wheel hitch in a 97 F150 4x4, wasn't very hard. Drilled 4 holes per side, in frame and bed. Total of 8 in frame and 8 in bed. Make sure you measure at least twice and then twice again. Some cross-bed tool boxes can be used with 5th wheel depends on height of box, approx 6" needed for clearance between bed rails and bottom of trailer. Toolbox comes into play when making extremely sharp turn.
Old Nov 24, 2002 | 09:35 PM
ImxNavy's Avatar
ImxNavy
5th wheel
