Hi is there some one that can help me I’m trying to replace fuel pump relay on a 1988 f150 x l tI have the part but can not locate part under the hood I was told driver side front of wheel well relay block still having a hard time locating part HELP!
Reason: wrong year
should be directly under the place that you pour brake fluid in. should be with another realay in a plastic tray/box mounted to the drivers inner fender. you'll see some wiring harness plugs to the right, the relay could've been taken out of the tray/box and mixed in with them. It looks like a wiring harness plug with wires only coming out of one end.
