Ford steering spindle
Old Mar 20, 2009 | 05:02 PM
82f-100's Avatar
82f-100
Is there a difference between a 1982 f-100 and 1982 f-150 steering spindle?Im wanting to change my f-100 small bolt pattern to the 5 on 5.5 bolt pattern but f-150 rotors seem to sick out to far on the f-100 spindles.
Old Mar 21, 2009 | 10:31 AM
Franklin2's Avatar
Franklin2
The best thing you can do is get the whole axle piece, and bolt it in on both sides. In other words, the whole beam.
Old Mar 21, 2009 | 11:33 AM
82f-100's Avatar
82f-100
is there an actual difference in the i-beam form an f-100 to f-150 as far as dimensions in 1982.i found the spindles or what some call the steering knuckle with rotors for $150.00 off of a early 80s f-150 for both sides. will this work to convert to a 5 on 5.5 lug pattern?
Old Mar 21, 2009 | 04:30 PM
Franklin2's Avatar
Franklin2
If you want to do some detective work, go to some place like Auto Parts Fast at RockAuto, plug in one truck, and then the other, and see if they have the same part numbers. For instance, if you plug in the balljoints, and they are not the same, I would say the spindles are not going to interchange. You could also check wheel bearings and rotors and calipers.
I am pretty sure though, the whole beam will bolt in, I believe some guys on here have done it before.
