Instant water heater
Ran the conduit for 220v just need to get off my backside and run the wire. Leaning towards propane and tankless; don't want to revisit the issue if decide to do something about the heating, or go with the elect. water heater which would be by far less labor intensive. Appreciate the suggestions, thank you!!.
In our garage with a guest room and "kitchenette" I installed a 30 gal electric WH from Sears. I left it on the 20 amp setting; it also has a 30 amp setting. That was satisfactory for a couple of showers when my sister and her hubby were down. BR sink runs off it too. For the "kitchenette", I have a 2 gal. electric under the sink. It is 120v 15a, and is on it's own 20a circuit.
So, I shut them off at the panel when not in use, and when guests are on the way, I click them on. For a party with no overnighters, I can just turn on that kitchen unit for hot water there.
Now I don't have freeze issues or need heat in the garage part, so that's a bit different maybe....
While doing some cyber shopping came across the 120v, 20gl electric water heater which has the on/off switch, hmmmm.
'Chaosracing' is right on, installing a tankless electric heater is not an option, if understand correctly, they require an 80A circuit, wow.
Also came across the G.E. Hybrid electric water heater, from what I was able to gather, works on water pump principle, using heat exchange. Claims to cut elect. cost inhalf, problem is it's not being introduced until 4th quarter of this year and not sure willing to wait. Also, assume G.E. will put the unit thru series of test and quality control procedures but usually not enthusiastic being among the first group to test any appliance or piece of equipment.
In meantime, arrange for local propane provider to come out for site inspection to determine if feasable to install a tank and still be able to route the pipe thru grove of redwoods.
Appreciate the input, still considering all options and have couple months before installing. Thanks!!
The new tax credits for energy star tankless (all tankless are rated energy star) you get 30% tax credit up to $1500 max for this year and next year. So if the unit costs $1500, that will mean a $450 tax credit. That includes this year and next year. So do garage this year, house next year.
No, you still qualify for the tax credits if you install yourself. Just talk to your tax guy about them. I believe all you need is some kind of documentation on the product and a copy of the sales slip.
Check out
How has the new Stimulus bill affected the tax credits for energy efficient home improvements?
It tells all kinds of info for heaters, windows, doors, insulation and other stuff.
Check out
Hey Dave,
I am using a tankless in my shop which includes a shower. It is a small unit with a 40 amp 220 volt current draw. I bought it from Ace Hardware on line and delivered free to my local store. It will provide enough "warm" water for a shower in the winter months even. No body had better turn on a faucet someplace else in the shop. I have been using it for 2 years. I had a 50 gallon electric which the utility company provided no charge but I estimated the monthly cost of keeping the water heater running was $25+ per month. I shut it off for 2 or 3 years before I bought the tankless unit. I love it!
POP
POP
#30
