Bar Hopping Truck, Needs Help
Old Mar 20, 2009 | 09:09 AM
bumper.45acp's Avatar
bumper.45acp
Last nite my truck just died. It didnt miss or sputter, it just quit and it just so happened it was right in front of the local bar, lol. The truck turns over fine, and I can hear the fuel pump running, although it sounds weak. It has sounded weak since I got the truck (about 3 weeks ago) Anyway I had my code reader in the seat and these are the codes I got:
81 82 87 84 33 41 95 96 Oh yeah its an 88 f250 4x4 c6 extended cab long bed. I know some of those codes are because the air pump is gone and the egr valve is disconnected (bought it that way). The truck has seemed a little underpowered since I got it. This evening I will check fuel pressure and see if I have spark, other than that I am lost and walking. One more thing, while checking the truck over I found the PO must have had a similar problem because the red and brown wires from the fuel pump relay are tied together with an added on wire from the fuse box.
Old Mar 20, 2009 | 09:21 AM
DasCheckers's Avatar
DasCheckers
Check back with more info when you have it man!
Code 33 - EGR valve opening not detected.
Code 41 - No HEGO switching detected.
Code 81 - Air management 2 circuit failure.
Code 82 - Air management 1 circuit failure.
Code 84 - EGR vacuum solenoid circuit failure.
Code 87 - Fuel pump primary circuit failure.
Code 95 - Fuel pump secondary circuit failure - PCM to ground.
Code 96 - Fuel pump secondary circuit failure - battery to PCM.
So it all points to your fuel pump.
Everything else is created by an incomplete EGR and smog removal. I can help you make these codes go away if you'd like.
Other than that troubleshoot your fuel pump!
Good luck.
Old Mar 20, 2009 | 10:29 AM
bumper.45acp
Thats kind of what I was thinking. I am assuming it would be the high pressure pump and not the in tank pumps.
And yeah I would like those EGR codes to go away, any help is appreciated.
Old Mar 20, 2009 | 10:49 AM
DasCheckers
Well as far as the EGR codes go you will need some of these parts.
RJM Injection Tech EGR Eliminators
Old Mar 20, 2009 | 06:17 PM
bumper.45acp
Well I have good fuel pressure at the rail, but I don't have any spark. I had the module checked at two different stores and it checked good twice. Not sure where to go from here. I pulled the codes again and its the same ones.
Old Mar 20, 2009 | 07:13 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Plug the vacuum line that is hooked up to the smog system and make sure all the electrical stuff is hooked up. This way you will not get any codes, I deleted my smog system, plugged that one line and everything is good. As for the EGR, reconnect it, even with the RJM eliminator kit you will likely have CEL problems. There is no good way to eliminate the EGR system.
mecsey33
Feb 28, 2015 06:45 PM
mecsey33
Dec 28, 2012 02:16 PM
Sunline Fan
Jun 21, 2011 11:57 PM
dakota-boy
Jul 28, 2009 01:21 PM
lleonard1
Jul 9, 2008 01:29 AM
