light harness and lights
Old Nov 30, 2002 | 07:46 PM
Wheels's Avatar
Wheels
I have not done this yet but here is my plan...(read *** grano salis)
I am going to add a separate connector between the truck and the trailer to run power for backup lights and eventually a camera mounted in the trailer to spy on the horses. The backup light power will come from a relay on the truck. The relay power will come from a fused connection to the battery and the relay control power will come from a switch in the cab. I plan to run this switch off of the park light power so that I cannot turn the backups on without the truck park lights being on also. I hope this will help prevent accidentally leaving the backup lights on and running down the truck battery.
Old Dec 1, 2002 | 07:47 AM
Gwilkrrs's Avatar
Gwilkrrs
red, thanks. the other post didnt show a diagram for me. you showed a post and how to check the hot. thanks. i'm going to have to unload the trailer it is stacked witjh trees going to the mill, so i can bring it in to the shop to check the wires.
if i can find the black wire and switch it at the trailer for the lights that way the lights only work if the truck is hooked to the trailer abd getting out to fire the lights wont be that hard. will let you know how i do! might be a little its cold out there!
Old Dec 8, 2002 | 05:40 PM
69_bronco's Avatar
69_bronco
On my '01 the factory 7-way trailer plug has a wiring diagram on the cover, and shows the center pin to be the backup lights.
Old Dec 28, 2002 | 09:30 PM
whitebenz's Avatar
whitebenz
Post light harness and lights
On the farm I have set all of the trailers w/batts for the breaks with a flat four way plug at the rear of the trailer and at the front of the trailer. I then have a cheap fog light that has a magnetic mount off of an old mag. mount c.b. antena and a pig tail that plugs into the flat four way plug so that I can see to hook up in the middle of nowhere at night or see to back up in the middle of the night. By having it magnetic I can move the light from trailer to trailer and position it anywhere I need light on the trailer in or out.
hope this helps
dj
Old Dec 29, 2002 | 03:02 PM
Gwilkrrs's Avatar
Gwilkrrs
that sounds good, could you let me in on how you wired the batt with the 4 way? did you simply tap into the bat?
Old Dec 29, 2002 | 03:13 PM
whitebenz's Avatar
whitebenz
Yes I used the ground sideof the plug for ground and the brown wire for hot. An ran a wire from the brake batt to the brown wire.
dj
Old Dec 30, 2002 | 09:06 AM
Buckarcher's Avatar
Buckarcher
Wow, long thread, lots of discussion, and nobody mentioned pouring more concrete at the end of the lane so the trailer could be turned around. Actually, I am the type that would make the driveway bigger AND hook up the lights.
Just thinkin' outside the box here. "Give Me Forty Acres and I'll Turn This Rig Around" Anyone else remember that song?
Old Dec 30, 2002 | 11:45 AM
Redexpy's Avatar
Redexpy
"Some guys can turn it on a dime
or turn it right downtown,
but I need forty acres
to turn this rig around!"
Yes, I remember that song.
Happy New Year, all. Red
Old Dec 30, 2002 | 07:03 PM
Gwilkrrs's Avatar
Gwilkrrs
some of us would need a large circle to turn our rides around with the trailers
Old Dec 30, 2002 | 10:03 PM
nafzimo's Avatar
nafzimo
How about installing street lights up the lane?
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Dec 31, 2002 | 05:36 PM
Gwilkrrs's Avatar
Gwilkrrs
now thats using your noggin!:7
lamplights would be a nice addition!
now you have me really thinking of the possibilities
Old Jan 1, 2003 | 03:09 AM
whitebenz's Avatar
whitebenz
dj
Old Jan 1, 2003 | 12:26 PM
  #28
SoCalDesertRider's Avatar
SoCalDesertRider
1fixitman
Jun 6, 2018 07:20 AM
Myfreeford
May 3, 2012 10:13 PM
communicator
Jul 24, 2010 09:44 AM
fencer
Electrical Systems/Wiring
Sep 20, 2009 12:42 PM
ccrider966
All Things Towing
Sep 19, 2004 02:50 AM
