any ideas
Old Mar 20, 2009 | 06:41 AM
dougf2504x4's Avatar
dougf2504x4
any ideas
i have a 88 250 4x4 5.8L c6 i changed the flywheel and also changed the trans filter/gasket now it will only go in reverse and if u hit the gas hard it will start to catch a lil no 1 2 or D fluid level is good all connectors and lines are hooked up any ideas thanx Doug <!-- / message --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --> <!-- END TEMPLATE: ad_showthread_firstpost_sig --> <!-- controls -->
Old Mar 20, 2009 | 10:53 AM
Conanski's Avatar
Conanski
An automatic tranny doesn't use a flywheel, hope you meant flexplate. Is the new one exactly the same as the old one?
Old Mar 20, 2009 | 02:23 PM
dougf2504x4
yes the old flexplate was exactly the same
Old Mar 20, 2009 | 02:35 PM
460/5's Avatar
460/5
Zombie Survivalist
you might need to tear down the trans again, sounds like you might have some gunk blocking your lines.
