#1 at what height generally would you have to up grade to longer shocks
putting 2.5 tuff country lift intended for a diesel but has 5.4
so im thinking it will end up being 3+"of lift instead of 2.5
truck has plow and tow package and already sits level
front actually looks a little higher than rear
#2 comes w/track bar drop bracket will i need adjustable track bar
and drop steering arm
#3 also trying to figure rear -going with f 350 blocks think ill need more maybe add-a-leaf too
2004 f250 fx4 SC SB 5.4
in for a rough ride i know
any advice thank you
Shocks are good for about 2" beyond stock. Anything (lift or lowering) more than 2" I would get new shocks for the next level (4" lift in your case.)
Because it has a new bracket, it should off set the track arm. Your going a little more than it's intended most likely, but the stock bar will most likely be fine. You can always add one later if you find the axle is offset.
I think it would be easier to put the front together, and figure out what you need for the rear. Then buy the right size block and ubolts.
thanks ReAX for response and advice there couldnt be a better place to get this kind of info. truck is just about needed daily so dont wont to tie it up waiting for parts wanna make it a weekend project
im shure this same "cheap"lift has already been done a bunch of times w/ same truck
(i know it wont be cheap in the end) will try and take advantage of bilstien buy 3 get one free offer you just gave me the go ahead haha.
now to guesstimate the rear? anyone done this same "cheap" lift
You will not be down, the truck can drive while the front is jacked up and the axle a little off center. Although in your position, I would get a new/adjustable track arm. Then measure the distance between the top of the tires and the top of the wheel well. The difference front and back, plus 3" should tell you how much block you need.
i guess i could drive for a couple days like that
maybe ill just get a big empty cardboard box and rachet strap it in bed
lol
