Crate engine or rebuild?
Old Mar 19, 2009 | 06:15 PM
RangerJ1's Avatar
RangerJ1
1989 2.9 4x4 xlt auto. I need either to rebuild my engine or buy a crate engine what is a good price range for both options? And if you suggest putting in a 4.0 list what extra parts I will have to buy to make it work in this year model,Thanks
Old Mar 20, 2009 | 04:52 AM
wendell borror's Avatar
wendell borror
Your in luck, the 4.0 is plug and play in an 89. All you need is an early OBD I 4.0 and it's computer, the harness should work. With the 88 and down it gets a little more involving, but 89 and up were the golden years for a 4.0 swap.
Old Mar 20, 2009 | 06:23 AM
Pablo-UA's Avatar
Pablo-UA
yeah, 2.8 2.9 and 4.0 share bolt pattern, but 4.0 tranny is a bit enforced. different clutch packs
Old Mar 21, 2009 | 08:09 PM
bcjim's Avatar
bcjim
Wouldnt doing this be more $ that the whole rig is worth?
Old Mar 21, 2009 | 09:09 PM
RangerJ1's Avatar
RangerJ1
Yes you are right. But I have so much invested so far that I cannot scrap it. New trans ,radiator,ac (total repair) ,power steering pump,intake manifold gasket,springs all around,air shocks, rhino lining bed liner, and a host of other ankle biting stuff. So I have to fix it. I am going to have the bottom end done and go from there. The truck does not use oil or leak, all is well except oil pressure and the ticking. So I will hope this will fix for the time being. If I had the coins I would do the 4.0 swap. but that is not an option right now. Thanks
